I have Autodesk 2013 Mechanical. I recently got a new widescreen monitor and now at least once a day, I get the fatal error e0434352h exception at fd53940dh when trying to restore a minimized screen. I have tried all different options with the computer resolution, but they do not seem to work.
Solved by Steve_Bessette. Go to Solution.
You may want to take a look at your system to verify if you have a dual graphic card setup. If you do, you may want to set AutoCAD to only run with the high performance card as opposed to the intigrated graphics card. Please refer to the link below for additional information.
AutoCAD crashes when opening or closing drawings on laptops with dual graphics cards
If this resolves this issue, pleace check "Accept As Solution".
Best Regards,
