AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Fatal Error when trying to restore a minimized screen
2 REPLIES 2
kmgriff
657 Views, 2 Replies
I have Autodesk 2013 Mechanical.  I recently got a new widescreen monitor and now at least once a day, I get the fatal error e0434352h exception at fd53940dh when trying to restore a minimized screen.  I have tried all different options with the computer resolution, but they do not seem to work.
2 REPLIES 2
newbies
in reply to: kmgriff
Hye Kmgriff,
Maybe you should upgrade your Graphic Card and RAM.
Autodesk Inventor 2013.
Autodesk AutoCAD 2013.
Autodesk AutoCAD Mechanical 2013.
Steve_Bessette
You may want to take a look at your system to verify if you have a dual graphic card setup.  If you do, you may want to set AutoCAD to only run with the high performance card as opposed to the intigrated graphics card.  Please refer to the link below for additional information.
AutoCAD crashes when opening or closing drawings on laptops with dual graphics cards
If this resolves this issue, pleace check "Accept As Solution".
Best Regards,
Steve Bessette
Support Specialist
Product Support
”Boost
