AutoCAD Mechanical General Discussion
Valued Contributor
Mike686
Message 1 of 14 (7,617 Views)
EXPRESS TOOLS don't work
7617 Views, 13 Replies
04-03-2011 05:32 PM
hi, i install the express tool after i installed autocad mechanical 2011 and the menu is there but none of the commands like auto text numeribg and explode attributes to text,  works..
any ideas why?
Product Design Suite 2013
i have repair the product a second time and now its seem to work fine
thanks again
Employee
Sridhar-Autodesk
Message 2 of 14 (7,593 Views)
Re: EXPRESS TOOLS don't work
04-04-2011 07:16 PM in reply to: Mike686
Try following steps and verify if it works.
Step 1 >> CUILOAD the cui file “acetmain.cuix”>>Express Tool panel is listed in the ribbon
Step 2 >> APPLOAD 2 FAS files(acettest.fas and acetutil.fas) from the express menu, refer to the image attached.
Let me know if this helps
Sridhar Subramani
Valued Contributor
Mike686
Message 3 of 14 (7,543 Views)
Re : EXPRESS TOOLS don't work
04-16-2011 12:24 PM in reply to: Mike686
i try to do what you said but when i try to load the application, theres no .fas listed in the express folder...
Employee
Sridhar-Autodesk
Message 4 of 14 (7,537 Views)
04-17-2011 07:16 PM in reply to: Mike686
Please try suggestion in the following thread first, then followed by my previous suggestion to load the *.fas files.
http://forums.autodesk.com/t5/AutoCAD-Mechanical/adding-express-tools-menu-after-installation/m-p/26...
Sridhar Subramani
Valued Contributor
Mike686
Message 5 of 14 (7,508 Views)
04-21-2011 12:13 PM in reply to: Sridhar-Autodesk
thanks again
Active Member
Muijsenberg
Message 6 of 14 (6,425 Views)
09-30-2011 04:11 AM in reply to: Mike686
I had the same problem express tools didn't work even after reinstalling.
After installing SP1 the problem still existed.
Loading the fas files was for me the solution, now all funtions work as they should.
Problem solved.
:smileyvery-happy:
New Member
rmalouff
Message 7 of 14 (5,632 Views)
03-05-2012 10:28 AM in reply to: Sridhar-Autodesk
Structure 2012
I went through the steps of unloading a reloading Express tools, and then the steps metioned above and had txt2mtxt working.  Now it does not work.
I went through the steps mentioned above and now get:
"Unable to load customization file:
That Customization Group already exist."
Didn't we pay to have the programming for this package completed by Autodesk?
Valued Contributor
jedenton
Message 8 of 14 (4,447 Views)
11-19-2012 12:14 PM in reply to: rmalouff
have the same problem,,,load the two .fas files,,,corrected the problem in the working drawing only,,will not auto re-load on new drawing,,,have to appload everytime..??
Employee
Sridhar-Autodesk
Message 9 of 14 (4,436 Views)
11-19-2012 04:47 PM in reply to: jedenton
You may try to add them to "Startup suite"
Command: Appload>>Contents>>Add>>Browse and add both files
Hope this helps,
Sridhar Subramani
Member
ronsearcy
Message 10 of 14 (4,093 Views)
02-20-2013 09:20 AM in reply to: Sridhar-Autodesk
AutoCAD Architecture 2013 Building Design Suite, I'm having the same problem of "Convert to Mtext" not working. I've tried the APPLOAD> process several times without success, it remains "txt2mtxt Unknown command". And I couldn't access AutoCAD through Win7 Control Panel>Programs. Any other suggestions? Thank you in advance.
