I am trying to export some files to our customer in Microststion .dgn format.
When I run the export utility it prompts me to select a seed file and the pull down pick list for seed file contians none but the tool tip that hovers states that several sample seed files are provided upon installation.
How do I get to the sample files?
No .dgn files were found in a search of my drive, attempt to add Autodesk components thru Windows add/remove programs did not appear to contain anything but Inventor Link.
Please advise how I aquire a seed file necessary to export these files for our customer.
You can use the sample seed files in the following path,
C:\Users\<user name>\AppData\Local\Autodesk\AutoCAD 2012 - English\R18.2\enu\Template. If you are using Windows XP, the path will be slightly different. The one here is for windows 7.
Hope it helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
