I was able to export a few DWG files to PDF format on a project. I went to do this with another project and it fails everytime. I am using AutoCad mechanical 2015. It says there were no sheets to export. I do not use sheets and there were no sheets on the ones that worked. I am attaching one of the files that will not export.
Solved by Keshava_Murthy. Go to Solution.
There is no any issue to plot to pdf. Please see attachment test.pdf
There is no any issue to Publish to PDF, Please see left AIR PNEUMATICS.pdf.
I suspect the publish options cause the issue. Please check there.
Please check the pagesetup settings:
Modify the page setup manager to print to DWG to PDF.pc3, save the settings and then try to export to PDF.
Attached dwg is with the updated settings.
