Much of the content of my exported STEP file is missing
I am using AutoCAD Mechanical 2013 & SolidWorks 2013
Can you give basic advise on what may be wrong, apart from the part I'm no expert in either package.
I am not sure how you exported STEP in Solidworks. If you want to do it in AutoCAD Mechanical, you can first use IMPORT command to import the models into AutoCAD Mechanical. Then use STEPOUT to export the step file.
If that doesn't help, please send me (zhiyuan.su@autodesk.com) a sample model for a look.
STEPOUT in AutoCAD supports two different AP's (Application Protocol) 203 C2/C4/C6 and 214 C2.
But STEP files make only sense if you export 3D solid models.
For a complete translation scheme from AutoCAD entities to STEP entities AP203/AP2014 see the step help file in your AutoCAD Mechanical 2013 installation at C:\Program Files\Autodesk\AutoCAD 2013\Help\step_16_0.chm.
And if you export from AutoCAD to Solidworks and there is something missing that should there try the "cycle test".
After exporting from AutoCAD to STEP make an IMPORT to AutoCAD again. If then is something missing, that should not, according the translation scheme in the help file, then you have a problem.
Hope that helps.
If you still can't figure it out - attach your original file and the STEP file here (or indicate in some other way (like screen captures) what is missing).
JD,
Just following the thread in search of another conversion process. I tried the same procedure as a STEP File however from regular AutoCAD the conversion does not work. Am I missing a command? Please refer to my attached File.
BTW.. thanks again for your help with the "STL" conversion files
@Drafter1981 wrote:
..I tried the same procedure as a STEP File however from regular AutoCAD the conversion does not work. ...
I've read this several times and I don't understand what you are trying to do or what your question is?
JD,
Basically I would like to export out to STEP, (STEPOUT command, or print to 3D command).
That being said,
I guess what I really would like to know is if there is another version of AutoCAD besides Mechaical or "MEP" that can export to STEP?
The more I dig into this the more I'm finding out, and that the "Older" versions of AutoCAD had the same functionality of MEP.
This brings me to another question...
"What is the best, or most useful version of AutoCAD, or an Autodesk prouduct to use for exporting to a 3D STEP file"?
Autodesk Inventor will save as STEP.
(I think Fusion 360 will, but not sure.)
For 3D printing most any Autodesk product will save as *.stl format.
Thanks again JD,
I'm still investigating what or which program is the best overall.
I feel bad telling my friends and customers to use this site (meaning Autodesk in general) to get answers or to promote software and there is not one program or person from Autodesk that can give my friends, co-workers, my customer or me a straight answer on what to use.
Thanks again for your Help and Information.
Sincerely,
Milt (a.k.a.: Drafter1981)
I just went through all of the threads you have posted here.
I have no clue what your industry is or what you need to do.
Based on the fact that I have no clue what you need to do - I could not possible make any recommendations myself.
Except to recommend that you have your VAR do an on-site visit to discuss your needs.
Milt,
Did you ever come up with a needs/problem description?
JD,
Thanks for writing back or asking.... and the answer is "NO".
It seems the only people that have been responding are the gurus like yourself
I actually only received responses from Dean (pendean), and Melanie Perry (Wonderer-MOTD).
To answer the question about what trade, or industry...,as a consultant I've been working with everyone.
This recent project is for "Mechanical" but the parts to be manufactured, or developed,
are for the "Construction/ Architectural field". The "Cone, Loft or Helix / STL from AutoCAD"
that you helped me with, was for "Industrial Design / Educational Purposes"
to show other students what can be done with a 3D printer
I guess working with other trades is not high on anyone's list.
Personally I just feel bad about not being able to help or at the very lease,
be able to give someone answer about purchasing software.
Thanks anyway for all of your help.
I'm not sure about working with Maya, which is why I asked on on of my post "What is the Best Autodesk Product for File Conversions?"
That being said, I guess Autodesk is pushing multiple products or suites for guys like me, since I seem to work in multi-discipline or with different industries.
As far as using AutoCAD MEP, it should export to STEP however, this past year, after getting involved with 3D printing, I have found that "STL" seems to be the way to go for 3D exports (refer to JD' comment: STL Files from AutoCAD for 3D printers) .
Obviously anything larger than the 3D print bed needs to converted into another format, or drawn on a different CAD system.
Hope this helps. Take care and have a good Holiday (Happy New Year's 2015).
Milt
