AutoCAD Mechanical General Discussion
Member
Bsmall
Message 1 of 7 (3,789 Views)
Escape key not working in 2011 Autocad Mechanical
3789 Views, 6 Replies
10-26-2010 05:15 AM
Hello Everyone,
I have recently upgraded to Autocad 2011 Mechanical and I have noticed that when I select a line, block, or solid and I try to deselect it by hitting escape.  It will not deselect the object.  I did find on another thread that this has happened on Autocad 2011 MAP 3-D program and that there was a hotfix.  However, I do not think that hotfix applies to Autocad 2011 Mechanical.
Is this a known issue and is there a fix for it?  Thanks in advance for the time.
EDIT:  I have tried the PICKFIRST command as well and it did not work either.
*Pro
Modman_4
Message 2 of 7 (3,779 Views)
Re: Escape key not working in 2011 Autocad Mechanical
10-26-2010 06:32 AM in reply to: Bsmall
http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Member
Bsmall
Message 3 of 7 (3,777 Views)
10-26-2010 06:37 AM in reply to: Bsmall
Thanks for the reply, but based on your response I am assuming I should post my question on that forum?  I searched that forum for my problem and did not find anything that matched it.
SlowCad
Message 4 of 7 (3,698 Views)
10-27-2010 01:20 AM in reply to: Bsmall
Maybe it's got something to do with SP1, because it's one of the issue's mentioned here:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/Autocad-Mechanical-2011-problems-after-installing-U...
Try uninstalling SP1 and see if this helps.
Distinguished Contributor
PaulB108
Message 5 of 7 (3,413 Views)
11-03-2010 08:05 PM in reply to: SlowCad
I am having the same issue. Installed from the Inventor 2011 Professional discs.
Anyone come up with a fix yet?
Inventor Professional 2014.
Windows 7 64 bit.
thomasjlandry
Message 6 of 7 (3,030 Views)
11-22-2010 01:16 PM in reply to: Bsmall
same problem, only I have been running 2011 for months and it just started happening today.
*edit* restart Autocad and I'm back to normal (well, the esc key is back to normal, anyway...)
pkompier
Message 7 of 7 (1,174 Views)
02-28-2012 01:13 AM in reply to: thomasjlandry
Re-install the ATI video driver software. http://forums.adobe.com/message/2977659
Kind regards,
Peter Kompier.
