AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Escape key not working in 2011 Autocad Mechanical
6 REPLIES 6
BSMALL
4476 Views, 6 Replies
Hello Everyone,
I have recently upgraded to Autocad 2011 Mechanical and I have noticed that when I select a line, block, or solid and I try to deselect it by hitting escape.  It will not deselect the object.  I did find on another thread that this has happened on Autocad 2011 MAP 3-D program and that there was a hotfix.  However, I do not think that hotfix applies to Autocad 2011 Mechanical.
Is this a known issue and is there a fix for it?  Thanks in advance for the time.
EDIT:  I have tried the PICKFIRST command as well and it did not work either.
6 REPLIES 6
Modman_4
in reply to: BSMALL
http://forums.autodesk.com/t5/AutoCAD-Mechanical/bd-p/39
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! 🙂
BSMALL
in reply to: BSMALL
Thanks for the reply, but based on your response I am assuming I should post my question on that forum?  I searched that forum for my problem and did not find anything that matched it.
jbogaard
in reply to: BSMALL
Maybe it's got something to do with SP1, because it's one of the issue's mentioned here:
http://forums.autodesk.com/t5/AutoCAD-Mechanical/Autocad-Mechanical-2011-problems-after-installing-U...
Try uninstalling SP1 and see if this helps.
HarryP108
in reply to: jbogaard
I am having the same issue. Installed from the Inventor 2011 Professional discs.
Anyone come up with a fix yet?
Inventor Professional.
Windows 10.
thomasjlandry
in reply to: BSMALL
same problem, only I have been running 2011 for months and it just started happening today.
*edit* restart Autocad and I'm back to normal (well, the esc key is back to normal, anyway...)
pkompier
in reply to: thomasjlandry
Re-install the ATI video driver software. http://forums.adobe.com/message/2977659
Kind regards,
Peter Kompier.
”Boost
