Hi all,
I'm using AutoCAD Mechanical 2015 and wanted to create a Detail View in my Layout.
When I click on the Button for a circular detail view, I get this error:
Unable to perform the requested action. This drawing was last edited with model documentation in a newer version of AutoCAD.
I am the only one editing this document.
How can I fix this and get the detail views?
Thanks.
Hi
Is AutoCAD Mechanical 2015 SP1 installed? If it's not installed; install from the following location and verify the issue.
To check if AutoCAD® Mechanical 2015 SP1; Launch the application and try the command AMVER
If the command like lists AutoCAD® Mechanical 2015 SP1, please attach a copy of drawing to this thread or send to sridharDOTsubramaniATautodesk.com
Thanks for the reply,
SP 1 wasn´t installed so I did it now, but it did not solve the problem.
The drawing is a task for my university, so I could get into trouble, if I post it online, but I tried the same thing with the example file "Lever Detail.dwg" and got exacly the same error.
My Version is now AutoCAD® Mechanical 2015 SP1.
Thanks for your help.
I think I found a solution:
If I use the command AMDETAIL, everything works.
Well, it is not really a solution but I can live with that.
