AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Error ACAD 2015: Can't create detail view
3 REPLIES 3
black-8
1118 Views, 3 Replies
Hi all,
I'm using AutoCAD Mechanical 2015 and wanted to create a Detail View in my Layout.
When I click on the Button for a circular detail view, I get this error:
Unable to perform the requested action. This drawing was last edited with model documentation in a newer version of AutoCAD.
I am the only one editing this document.
How can I fix this and get the detail views?
Thanks.
3 REPLIES 3
Sridhar-Autodesk
in reply to: black-8
Hi
Is AutoCAD Mechanical 2015 SP1 installed?  If it's not installed; install from the following location and verify the issue.
http://knowledge.autodesk.com/support/autocad-mechanical/downloads/caas/downloads/content/autocad-me...
To check if AutoCAD® Mechanical  2015 SP1; Launch the application and try the command AMVER
If the command like lists AutoCAD® Mechanical  2015 SP1, please attach a copy of drawing to this thread or send to sridharDOTsubramaniATautodesk.com
Sridhar Subramani
Senior Product Owner
black-8
in reply to: Sridhar-Autodesk
Thanks for the reply,
SP 1 wasn´t installed so I did it now, but it did not solve the problem.
The drawing is a task for my university, so I could get into trouble, if I post it online, but I tried the same thing with the example file "Lever Detail.dwg" and got exacly the same error.
My Version is now AutoCAD® Mechanical  2015 SP1.
Thanks for your help.
black-8
I think I found a solution:
If I use the command AMDETAIL, everything works.
Well, it is not really a solution but I can live with that.
”Boost
