AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
ERROR 114
3 REPLIES 3
JoeP
288 Views, 3 Replies
ERROR 114
When I click on the SP3 update exe I get the following message:
Error 114: The AutoCAD Mechanical 6 update was not applied.
I downloaded the exe file (AMECH6SP3.exe) from AutoCad.
The readme suggests running this program will unzip several files, but when I try to look at it with WINZIP it reports as an exectuable file, not an archinve.
Any ideas what is going on?
Joe
3 REPLIES 3
in reply to: JoeP
Just a thought, have you applied sp1 and sp2 yet? Also, on some spk's, you have to have the original installation CD in the tray. JRWalker "JoeP" wrote in message news:1610775.1085482146135.JavaMail.jive@jiveforum2.autodesk.com... > When I click on the SP3 update exe I get the following message: > > Error 114: The AutoCAD Mechanical 6 update was not applied. > > I downloaded the exe file (AMECH6SP3.exe) from AutoCad. > > The readme suggests running this program will unzip several files, but when I try to look at it with WINZIP it reports as an exectuable file, not an archinve. > > Any ideas what is going on? > > Joe
JoeP
in reply to: JoeP
Yes, we are running SP2. However, the CD was not in the tray. I'll give that a try. Thanks.
Joe
in reply to: JoeP
How did you resolve this? I get the same error.
I have the CD loaded when I try to run the file.
”Boost
