Hi, may i know if there any easy way to enter block editor? Example is from a drawing,when i double click a block, it will enter to the editor mode..currently when i double click a block, it sort enter into Reference Edit mode....
Solved by michaelsu. Go to Solution.
In AutoCAD Mechancial, when you double click a block, it will first invoke AMPOWEREDIT and then REFEDIT.
To get into block editor, you can use command BEDIT (BE) and select the block or you can select Block Editor item in context menu.
Michael Su
SQA Engineer
