AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
dwg to pdf.pc3 issue with acadm 2010
1 REPLY 1
3dforme
703 Views, 1 Reply
I recently loaded version 2010 coming from version 2009. When i plot to pdf in 2010 some lines and text are very faint at full zoom. When i zoom in on the pdf file everything appears fine. Plots fine too. I go back and open the same acad file in version 2009 and i have no problems. Anybody know what's causing this? I've tried to change every setting to no avail. Noticed the new dwg to pdf.pc3 opens the pdf up. I like that but not how it displays at full zoom. Don't like using the adobe pdf plotter. Doesn't seem to retain correct rotation. Anyway I can load version 2009 dwg to pdf.pc3 into version 2010 so I can move on with life. Still trying to get comfortable with 2010.
Mike
1 REPLY 1
3dforme
in reply to: 3dforme
Problem solved and posted in next thread. I changed the custom properties for the dwg to pdf.pc3 for vector resolution from 600 to 400. That's how it was set in version 2009. Hope this helps.
”Boost
