Has anybody been able to figure out why we keep getting inconsistent results? Is there a service pack fix? This is so frustrating since i'm making pdfs constantly through out the day. No problems at all with 2009 version. What gives?
1 minute the pdf is readable and then the next time not with the exact same file. Please autocad fix this issue!
I am not sure exactly what problem you have. But at least you can try updating AutoCAD 2010 Update 2 to see if the problem goes away.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15074619&linkID=9240618
Michael
Software QA Engineer
I'll try the update to see if it fixes the issue with the dwg to pdf.pc3 converter. Guess i got used to using it in version 2009.
I started using the Adobe PDF converter and setting the paper size to tabloid and so far so good. I liked the full bleed paper sizes with the dwg to pdf.pc3 but until i get it straigtened out i'll use what's working. I was getting very light looking pdfs instead of nice and bold as with the 2009 version of dwg to pdf. All I know is I was not doing anything different when i started using this converter going from 2009 to 2010 and i'm getting inconsistent pdf quality.
