AutoCAD Mechanical General Discussion
Member
noodle_snacks
Message 1 of 9 (819 Views)
Drawing an Auger
819 Views, 8 Replies
04-28-2005 04:05 PM
Hey,
How can i use AutoCad or AutoCAD mechanical to draw a large auger? Do i need to use an autoLISP script from somewhere or is there a built in function?
Distinguished Contributor
JDMATHER
Message 2 of 9 (819 Views)
Re: Drawing an Auger
05-02-2005 07:36 AM in reply to: noodle_snacks
2d or 3d?
Member
noodle_snacks
Message 3 of 9 (819 Views)
05-02-2005 11:57 PM in reply to: noodle_snacks
I want a 3d model with 2d plans. Normally i wouldn't bother trying to draw screws and threads etc, but it is a key part of the drawing.
JDMATHER
Message 4 of 9 (819 Views)
05-03-2005 08:05 AM in reply to: noodle_snacks
You probably need MDT or Inventor. AutoCAD and Mechanical are not really 3D modelers. There are a few 3D "helix" and "spiral" lisp routines for ACAD floating around, but I have not seen particularly good results. Try a search on these terms to find them.
Do you have some specs for your auger?
Member
noodle_snacks
Message 5 of 9 (819 Views)
05-03-2005 02:34 PM in reply to: noodle_snacks
I don't have the specs for the auger yet but i do have autocad inventor. At a guess it would be about 150mm in diameter and 2000mm high, unsure about actual thread
JDMATHER
Message 6 of 9 (819 Views)
05-04-2005 06:32 AM in reply to: noodle_snacks
The program is Autodesk Inventor not Autocad.
When you are ready to give it a try you might want to post the specs at the Inventor forum:
http://discussion.autodesk.com/forum.jspa?forumID=78
This isn't exactly what you are doing but is related. Check the Worm.zip
http://discussion.autodesk.com/thread.jspa?threadID=401568
Pull down the red End Of Part marker (usually referred to as EOP). Doing a coil is fairy trivial in Inventor.
mooresk257
Message 7 of 9 (819 Views)
05-04-2005 12:17 PM in reply to: noodle_snacks
OK, what about 2d then? In AM 2005? This is a good topic. I have a project coming where I'll need to draw an auger-like object.
JDMATHER
Message 8 of 9 (819 Views)
05-05-2005 05:08 AM in reply to: noodle_snacks
5 minutes work
JDMATHER
Message 9 of 9 (819 Views)
05-05-2005 05:09 AM in reply to: noodle_snacks
5 minutes 5 seconds work
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
