You seem to have a lot more options with Power Dimensioning, just by
clicking on a line, you can get vert., horiz., and aligned dimensions.
Also, dots automatically replace arrows if the gap between extension lines
is too small.
You can break extension lines for dimension lines or text from another
dimension.
Automatic spacing of dimensions.
Power erase on a baseline dimension automaticaaly moves all other dims.
Plus others that I forget.
Bairdo.
"Jim Shipley" wrote in message
news:41def9d5$1_3@newsprd01...
> What is the difference between Power Dims and regular dimensions? Once
they
> are created aren't they the same?
> "Bairdo" wrote in message
> news:41dc7027$1_3@newsprd01...
> > Jerry,
> > Are you using Power Dimensioning or plain old autocad dimensioning?
Power
> > Dimensioning uses only 1 dimstyle also.
> > Don't you find yourself flipping out (yup, pun intended,) of modelspace
> into
> > paperspace to real a dimension, and then back to modelspace?
> > Baird.
> > "lsaapedd" wrote in message
> > news:13642209.1104965246113.JavaMail.jive@jiveforum2.autodesk.com...
> > > I use PS. I like having only one dimstyle, set in my template. Text
is
> > the size I want, no scaling. There are some minor problems; sometimes a
> dim
> > will lose its scale factor, but it's easily fixed. Right now, I don't
put
> > anything in MS but the drawing.
> > > We operate an ammunition plant for the Army. We draw everything,
> > machines, plant maps, building layouts, whatever is needed.
> > > Jerry
