AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Dimension problems
2 REPLIES 2
jpnick
276 Views, 2 Replies
Dimension problems
I am having trouble with dimensions that I have changed or stretched returning to there previous locations or dim text. Example is that if I change a length of an object from 3" to 4" by stretching it. This of course is an object that is already dimensioned at 3". It will change to 4" initiallly & look correct, but lets say I save & close down the drawing & reopen it. A lot of the times my dimension reads 3" again with the extension lines in the 3" position again! This is a very troublesome issue for sure!
2 REPLIES 2
ksmith84
in reply to: jpnick
Hello. I did some searching online for dimension associativity, since your problem sounds similar... Check out this thread link n see if it helps ya any! 🙂
http://forums.autodesk.com/t5/AutoCAD-2000-2000i-2002-DWG/DIMENSION-GLITCH/td-p/1266571
Which OS and version of Autocad do ya use? (asking since there are threads of Windows 7 issues).
^C^CMoonwalk
jpnick
in reply to: ksmith84
Thanks for the help. I have windows 7. I have read the post you sent me & I have tried setting the dimassociation at 1 to 2 setting. I cannot get the problem to occur for me either way now. It is like there are gremlins that affect my drawings at certain times.
”Boost
