AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
dim issue in mech
3 REPLIES 3
306 Views, 3 Replies
dim issue in mech
i pull a dimension in mechanical it reads 44'-8 7/16"/536.407" i add tolerances via ampoweredit of +0 -1/8: my dim now reads 44'-8 7/16"/536.438" with the appropriate tolerance. i remove the tol and it goes back to .407. any idea of what is going on?
3 REPLIES 3
Hi rkahl,
If you don't mind, could you please attach your drawing here ? You can delete the rest and leave only that particular line in your dwg. I would like to help you out with this...
file attached the only diff in the 2 dimensions is the tolerence
file didnt attach, trying again in IE
”Boost
