AutoCAD Mechanical General Discussion
Distinguished Contributor
lhoang
Message 1 of 4 (557 Views)
delete button won't erase
557 Views, 3 Replies
05-08-2012 08:37 AM
I don't know what I did, but my delete button will not erase in AutoCAD Mechanical anymore. I used to be able to select geometry and hit the delete button and it would erase the lines out of the model space. Does anyone know how to change this setting?
I did try to set up a keyboard shortcut, but "DELETE" is not a valid input.
I did a repair on AutoCAD, but nothing changed. I don't think there is a problem with AutoCAD, I think a setting got changed somewhere.
Thanks for any help.
Make sure PICKFIRST is set to 1 and try if it's gone.
Employee
michaelsu
Message 2 of 4 (546 Views)
Re: delete button won't erase
05-08-2012 09:28 PM in reply to: lhoang
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
lhoang
Message 3 of 4 (542 Views)
05-09-2012 05:12 AM in reply to: michaelsu
Thank you and good job. This was the issue and you solved it for me. I didn't even know about this command! (nor how I changed it?)
New Member
jankutzlackie
Message 4 of 4 (120 Views)
07-17-2014 12:21 PM in reply to: lhoang
I just had to do this - out of the blue, erase and delete stopped working, after working for hours without intentionally changing ANY settings...  autocad 2015.
but thanks!  "pickfirst" was the answer.
