Hi fellas,
Im struggling to batch export DWG to STEP files.
I tried to use the ADXBATCH.exe:
C:\Program Files\Autodesk\AutoCAD Mechanical 2012\Degtools
added it in my search path in Mechanical and modified the acad-deg.bat to my existing Mechanical Profile:
"C:\Program Files\Autodesk\AutoCAD Mechanical 2012\acad.exe" %1 %2 %3 /p "/p "C:\Program Files\Autodesk\AutoCAD Mechanical 2012\acad.exe" /p <<ACADMPP>>"
But the Profile will not be recognized, Im attaching the error.
A bad profile is specified in the command line
files\autodesk\acadm
The current profile name in the registry will be used
I assume the path in the acad-deg.bat is my problem, but I still have no clue.
Thanks a lot for any help.
Cheers
Solved by MSchwank. Go to Solution.
This should work:
"C:\Program Files\Autodesk\AutoCAD Mechanical 2012\acad.exe" %1 %2 %3 /p "/p <<ACADMPP>>"
Thanks to Karlovac, a kind fella from cad.de.
