AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Default program issue
3 REPLIES 3
mwright1971
499 Views, 3 Replies
Every time I double-click on a dwg file, it automatically opens it with AutoCAD Architecture. I tried going to "open with" and setting the default program used to AutoCAD Mechanical, but it doesn't work the next time I double-click to open. I tried using "browse" and navigating to the AutoCAD Mechanical folder and choosing the ACAD.exe file straight from there, but that doesn't work either. If I open AutoCAD Mechanical first ,then double-click on the dwg file, it will open just fine in Mechanical.
Windows 7, AutoCAD 2012 (Factory Design Suite)
I attached a screen shot of the "open with" dialog box and you can see that there are two AutoCAD Apps in it. I don't know how to delete or clear the recommended programs. Remember, I did in fact click the browse button in the lower right and navigate to the AutoCAD Mechanical folder and selected the ACAD.exe file from there.
3 REPLIES 3
Jacob_Butler
in reply to: mwright1971
Use AutoCAD dwg launcher as the default program. Should be in C:\Program Files\Common Files\Autodesk Shared\AcShellEx for 64-bit.
__________________________________________________
Autodesk Certified Professional - Inventor
mwright1971
in reply to: Jacob_Butler
Awesome!!! Thanks Jacob, that did the trick.
mwright1971
Now I'm stuck again. I had to open a DWG file using 'DWG TrueView2014' to convert the dwg file to use with AutoCAD2012, now every time I go to open a dwg file directly from windows explorer, it opens with DWG Trueview. I followed the instructions that I got from Jacob that worked before, but it no longer works. I don't know what is different this time. Can anyone help? Thanks.
”Boost
