Every time I double-click on a dwg file, it automatically opens it with AutoCAD Architecture. I tried going to "open with" and setting the default program used to AutoCAD Mechanical, but it doesn't work the next time I double-click to open. I tried using "browse" and navigating to the AutoCAD Mechanical folder and choosing the ACAD.exe file straight from there, but that doesn't work either. If I open AutoCAD Mechanical first ,then double-click on the dwg file, it will open just fine in Mechanical.
Windows 7, AutoCAD 2012 (Factory Design Suite)
I attached a screen shot of the "open with" dialog box and you can see that there are two AutoCAD Apps in it. I don't know how to delete or clear the recommended programs. Remember, I did in fact click the browse button in the lower right and navigate to the AutoCAD Mechanical folder and selected the ACAD.exe file from there.
Solved by Jacob_Butler. Go to Solution.
Use AutoCAD dwg launcher as the default program. Should be in C:\Program Files\Common Files\Autodesk Shared\AcShellEx for 64-bit.
Now I'm stuck again. I had to open a DWG file using 'DWG TrueView2014' to convert the dwg file to use with AutoCAD2012, now every time I go to open a dwg file directly from windows explorer, it opens with DWG Trueview. I followed the instructions that I got from Jacob that worked before, but it no longer works. I don't know what is different this time. Can anyone help? Thanks.
