Long story short I received a bunch of DWG files that where created in Inventor 2010 from a vendor. Of course this 41 sheet drawing was in 41 different .DWG files. I need these files in one DWG file so I did a save as in inventor to convert it to an AutoCAD .DWG. While trying to use design center and the "From Template" options to copy each layout to one file I encounter a few problems. 1) Most of the geometry is imported into the new file but not all of it. Mostly the tables with the list of material are missing and a lot of the dimensions, leader lines part number call outs are scattered all over the drawing. I am at a loss as what to do. The image I attached shows on the left what the drawing should look like, the image on the right shows what gets imported when I copy the layout or "from template" the layout to the new drawing file.
