AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Copy array items
1 REPLY 1
298 Views, 1 Reply
Copy array items
Hi
when I copy a grope of items that was created in array from one layer to another layer
the status of the grope changes to the new layer , but the color stays like the origin layer
the array grope was created. Why?
I use AutoCAD mechanical 2014 student
thank you
Sivan
1 REPLY 1
The dynamic array (if you do not use arrayclassic) is basically a dynamic block: the block is moved to the new layer - the parts inside are not.
You could try setting everything to "by block" before array-ing them.
Additionally: watch it with array, most Mechanical functionality can't deal with it. (partrefs inside a dynamic block are ignored for example).
”Boost
