I have an Autocad Mech 2013 user that is experiencing issues with copy & paste. It will work for a period of time then suddenly stop. The drawing is checked out of Vault (2013 pro) on Windows 7, Mechanical 2013. We opened word, and did a copy & paste test there, and it still works. It just stopped in this drawing only. He has experienced this before and it appears to be drawing specific - he can open another drawing and it works. It just stops in one particular drawing. Any ideas what would cause this?
Solved by Winks87. Go to Solution.
Probably a corrupt file. Do an audit to see if that "fixes" anything which might effect the copy and paste command. Then maybe a recover.
If all else fails you might try creating a Wblock of the drawing objects into a clean template and to see if that fixes the problem.
That appears to be the case (corrupt file). This is the only dwg this happens to. We will give this a shot.
Thanks Steve.
