I have finally created the shell of the complex surface that you see. This is only a section of the part because I cannot show the whole thing for proprietary reasons. I formed solid surfaces using the network command. The problem is that it will not convert to a solid because the surface seams are not "water tight." When the network command created the solid surfaces, the surface seams do not exactly match the lines so there are gaps in all the seams. I have tried blending, patching, etc. and nothing works. Does anybody know how to convert this to a solid without losing the outlines and the shape?
