AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Convert DWG to IGES
56 REPLIES 56
Message 1 of 57
16533 Views, 56 Replies
Convert DWG to IGES
I have a DWG file that I need to convert to a IGES. Is there anyone that can do this for me? I do not have AutoCad nor do I know how to use it, so any help will be much help. Thanks Lonnie
56 REPLIES 56
Message 41 of 57
Thank-you so much!
Message 42 of 57
Could someone help me to convert these.DWG files to IGES? I need them for processing.
Thank you so much,
Beatriz.
Message 43 of 57
Hi, I need DWG files to be converted to IGS. Could anyone help me? Please give me your e-mail I will email them to you. Thanks so much!!!
Message 44 of 57
in reply to: Sridhar-Autodesk
Please help me DWG to IGES convert.
Here is the file  thank you.
Message 45 of 57
Rob67ert
Here you go.
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 46 of 57
in reply to: Rob67ert
thank you very much
Message 47 of 57
Rob67ert
If it is to big, you should scale it.
I just opened the file and did an igesout.
Robert
Message 48 of 57
ok. thank you
Message 49 of 57
can you help me to convert this file into iges?
Message 50 of 57
can you help to covert this file to iges?
Message 51 of 57
Rob67ert
Here an IGES file.
It is a 2D drawing, so it will stay 2D.
Robert
Message 52 of 57
controle3S4B5
hello, can you help to covert this file to iges?
Message 53 of 57
Rob67ert
in reply to: controle3S4B5
This is a 2D drawing. it makes no sense to convert it to IGES.
Robert
Message 54 of 57
controle3S4B5
Thank but i’m not manufacturated this item any iges/igs file. I have a Charmille (electrofil) and dwg is not compatible with my computer. Sorry my English isn’t very good because i’m French. lol
Message 55 of 57
Rob67ert
What sort of files can u use ?
Remember that form a 2D dwg i can only convert it to a 2D format.
Robert
Message 56 of 57
m_latz
Here is your converted DWG file.
@Rob67ert why should it make no sense when it is only 2D ? IGES file format specification supports 2D and 3D.
regards
Markus
Message 57 of 57
ananthakumar.mani
I believe you already know this, but may be you don't have a AutoCAD to convert this,
But I have to explain how to do this..(It should be helpful for everyone)
Kindly follow the steps which is available in the attached image.
Please accept the solution if you really wondering about this solution.
Regards
Ananthakumar
”Boost
