AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Convert DWG to IGES
56 REPLIES 56
Message 1 of 57
lawharrell
16467 Views, 56 Replies
Convert DWG to IGES
I have a DWG file that I need to convert to a IGES. Is there anyone that can do this for me? I do not have AutoCad nor do I know how to use it, so any help will be much help. Thanks Lonnie
56 REPLIES 56
Message 21 of 57
sandysatpute9
in reply to: lawharrell
can any one help me.....
i have 3D autocad file & i want to convert it into IGES format, so that i can use it in proe.
Message 22 of 57
JDMather
in reply to: sandysatpute9
What version of AutoCAD do you have?
Attach your dwg file here.
What version of Pro/E do you have?
You should be able to open the 3D dwg directly in Pro/E.
The CADWhisperer YouTube Channel
Message 23 of 57
artefacto83
in reply to: JDMather
I need to convert DWG to IGES files. But my file is too long (3.9MB in ZIP, 5.7MB in DWG,  can anyone help? Thanks!!!!!
Message 24 of 57
JDMather
in reply to: artefacto83
Answer this question.
Message 25 of 57
artefacto83
I hace Autocad 2000, thanks
Message 26 of 57
JDMather
You have posted in the AutoCAD Mechanical forum - not the AutoCAD 2000 forum.
I can't really remember that far back, but try the igesout command.
Message 27 of 57
I also need a dwg file converted to iges. Dwg version is AutoCAD 2004. See attached file.
Mfg is requesting ".igs or .stp/step format"
Any help would be appreciated.
Chad Collins
Message 28 of 57
avalyanarman
Message 29 of 57
bizozwell
I've got a test DWG file for you all that came from ShipConstructor and is giving me problem when I try to convert to DXF or IGES. I need to open in Cinema 4D. I've attached a test file. If this can be done I have 13 more that I'd definitely like to pay someone to convert to a C4D readable extension.
DWG:
https://drive.google.com/file/d/0B9UzD835biteTmlmMEMwcXFRZGM/edit?usp=sharing
Thank you so very much!
Message 30 of 57
cpsaks
Can anyone help to convert  from CAD to igs please.
Your earliest help will be greatly appreciated
Message 31 of 57
fjannik97
I have a .dwg File too and can`t convert it to .iges. I use AutoCAD 2016.
Message 32 of 57
JDMather
in reply to: Chad_ConProd
Here is the file.
Message 33 of 57
JDMather
in reply to: fjannik97
Here is the file.
Message 34 of 57
Hello ,
I need help converting  1 dwg. file to iges for programming  can you help me .  See attached
Thank you
Bruce Hayes
MMS
619 208-7254
mmsyachtmachining.com
3801 Gaines St
San Diego Ca.  92110
Message 35 of 57
Please see attached IGES file.
Sridhar
Sridhar Subramani
Senior Product Owner
Message 36 of 57
amol.sathe
Please sir help me any one to get convert the dwg file to iges file...
I am in great need and hurry ..Plz help me out !!!
Tags (1)
Message 37 of 57
bruceXU9LJ
in reply to: amol.sathe
Hi ,
You will need to address the AUTODESK community in a post , you will get
a reply and help quickly . They help me in 1 day .
Bruce
Message 38 of 57
File attached.
Sridhar
Sridhar Subramani
Message 39 of 57
sophie-lataste
Could anyone help me convert this dwg into iges? Tank-you
Message 40 of 57
Please see attached igs file.
Sridhar Subramani
”Boost
