can any one help me.....
i have 3D autocad file & i want to convert it into IGES format, so that i can use it in proe.
What version of AutoCAD do you have?
Attach your dwg file here.
What version of Pro/E do you have?
You should be able to open the 3D dwg directly in Pro/E.
I need to convert DWG to IGES files. But my file is too long (3.9MB in ZIP, 5.7MB in DWG, can anyone help? Thanks!!!!!
Answer this question.
@Anonymous wrote:
I hace Autocad 2000, thanks
You have posted in the AutoCAD Mechanical forum - not the AutoCAD 2000 forum.
I can't really remember that far back, but try the igesout command.
I also need a dwg file converted to iges. Dwg version is AutoCAD 2004. See attached file.
Mfg is requesting ".igs or .stp/step format"
Any help would be appreciated.
Chad Collins
I've got a test DWG file for you all that came from ShipConstructor and is giving me problem when I try to convert to DXF or IGES. I need to open in Cinema 4D. I've attached a test file. If this can be done I have 13 more that I'd definitely like to pay someone to convert to a C4D readable extension.
DWG:
https://drive.google.com/file/d/0B9UzD835biteTmlmMEMwcXFRZGM/edit?usp=sharing
Thank you so very much!
Here is the file.
@Anonymous wrote:
I have a .dwg File too and can`t convert it to .iges. I use AutoCAD 2016.
Here is the file.
Hello ,
I need help converting 1 dwg. file to iges for programming can you help me . See attached
Thank you
Bruce Hayes
MMS
619 208-7254
mmsyachtmachining.com
3801 Gaines St
San Diego Ca. 92110
Please see attached IGES file.
Sridhar
Please sir help me any one to get convert the dwg file to iges file...
I am in great need and hurry ..Plz help me out !!!
File attached.
Sridhar
Please see attached igs file.
