The CADWhisperer YouTube Channel
Can someone help me to convert this .DWG file to IGES? It is required for machining on VMC.
- Kedar
Heyy lonnie / Shridhar
Can you please convert the .dwg file to .iges please..
I have also attached the file..
thanking you in advance
regards/siddharth
Heey every one ..please help to convert the below file attacted in .dwg format into .iges format.
please i am urgent need..
regards/siddharth
Hi I also need to convert this file to an IGES file and I do not have AutoCAD Mechanical. Could someone please help me with this? Thank you in advance foryour help.
-Dolly
Find attached translated IGES file.
Hello! I would really appreciate if someone can convert these .dwg files to iges format. I have no possibility to do it by myself.
Thanks very much.
David
I have a DWG file that I need to convert to a IGES. I downloaded Inventor Fusion but wasn't able to make it work.
Kenny
Hi
Could someone please convert file below to Iges format.
Much appreciated.
Kind Regards
Jan Korff
This program is really helpful and easy to use: http://www.gidhome.com/
You can download the evaluation version for free, but geometry is limited to 25 surfaces and meshes are limited to 1000 nodes.
It worked perfectly for me.
Cheers.
Can anyone help me to transform a .DWG file in IGES please?
I am working in Autocad 2000. A few months ago, I was able to open my drawing with Mechanical Desktop and export it as an IGES file. Why is not working any more I don't know.
Instead of pop up window asking me for the name and path for saving, now he said that IGES processing complete but I can found 2 files: one has an .xlo extension that I never heard of and one has no extension at all.
I've sent those 2 files to vacuum forming people assuming that they can do something but it is not working.
Thank you in advance for your time and help
Lucia
This is a Mechanical Desktop file, not an AutoCAD Mechanical file.
Someone would need MDT and Inventor to translate.
I recommend you use the ACISOUT command and then post the results over in the Inventor forum for translation to IGES.
try the attached file.
