AutoCAD Mechanical General Discussion
Member
lawharrell
Message 1 of 29 (7,524 Views)
Convert DWG to IGES
7524 Views, 28 Replies
01-19-2010 02:08 PM
I have a DWG file that I need to convert to a IGES. Is there anyone that can do this for me? I do not have AutoCad nor do I know how to use it, so any help will be much help. Thanks Lonnie
*Dennis Jeffrey
Message 2 of 29 (7,524 Views)
Re: Convert DWG to IGES
01-19-2010 08:28 PM in reply to: lawharrell
You will need AutoCAD Mechanical at a minimum, MDT or Inventor will
generate NURBS curves which will be more accurate. Can you zip and post
the file (under 1.5MB) here?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Attend the "It's a Duesy II " Manufacturing Revival Conference
March 17th, 2010 More Information at:
http://teknigroup.com
Member
lawharrell
Message 3 of 29 (7,526 Views)
01-20-2010 05:52 PM in reply to: lawharrell
Thanks for the reply Dennis. I attached the file and zipped it. I hope you can make this happen. Thank you in advance.
Lonnie
Employee
Sridhar-Autodesk
Message 4 of 29 (7,526 Views)
01-21-2010 06:59 PM in reply to: lawharrell
Lonnie,
Find attached zip file containing 2 igs file. One translated using Surfaces and the other as NURBS Surfaces.
Sridhar
Sridhar Subramani
Member
lawharrell
Message 5 of 29 (7,527 Views)
01-23-2010 09:42 AM in reply to: lawharrell
Sridhar,
Thank you for your time and effort.
Lonnie
New Member
Capcanoe
Message 6 of 29 (7,527 Views)
02-02-2010 10:23 AM in reply to: lawharrell
I have a DWG file that I need converted to IGES but it is too large to post here. Could someone please help me.
JDMather
Message 7 of 29 (7,527 Views)
02-02-2010 11:58 AM in reply to: lawharrell
I'm not positive but I think free Inventor Fusion will do the conversion http://labs.autodesk.com
The file size limit is much larger over here http://www.augi.com
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
kedar_til
Message 8 of 29 (7,525 Views)
06-08-2010 07:16 AM in reply to: lawharrell
Can someone help me to convert this .DWG file to IGES? It is required for machining on VMC.
- Kedar
New Member
sid1988
Message 9 of 29 (7,268 Views)
08-14-2010 01:46 AM in reply to: Sridhar-Autodesk
Heyy lonnie / Shridhar
                                     Can you please convert the .dwg file to .iges please..
 I have also attached the file..
thanking you in advance
regards/siddharth
New Member
sid1988
Message 10 of 29 (7,267 Views)
08-14-2010 01:52 AM in reply to: Sridhar-Autodesk
Heey every one ..please help to convert the below file attacted in .dwg format into .iges format.
please i am urgent need..
regards/siddharth
