AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Conflicts between different versions of the same dependent assemblies
1 REPLY 1
722 Views, 1 Reply
Program for plotting in the background
- working well with AutoCAD 2012 with Win xp
- the SAMME PROJECT with AutoCAD Mechanical 2012 Win 7 64 shows:
"c:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets(1360,9): warning MSB3247: Konflikte zwischen verschiedenen Versionen der gleichen abhängigen Assembly wurden gefunden."
AutoCAD Mechanical 2012 crashed with "Unhandled Exception ... Der Vorgang ist aufgrund des aktuellen Zustands des Objektes ungültig" Line xxx
Line xxx is the end of the transaction: End Using
Thank you in advance!
Michael diAngelo
1 REPLY 1
michaelsu
Hello Michael diAngelo,
Seems about Microsoft.Net, does the machine finish Windows update? Did you send your issue report after the crash and fill in your email address?
Also, is it only specific to some certain drawing? If so, it would be helpful to share it for further look.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
”Boost
