AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
close command
7 REPLIES 7
Message 1 of 8
ScottSwens
3942 Views, 7 Replies
close command
When I try to hit the close command, I get the following message in the command line.
'close Command CLOSE is not available under SDI mode'
I cannot even close with the x in the corner. I have to exit out of AutoCad and restart.
7 REPLIES 7
Message 2 of 8
Set SDI system variable value to 0
Command:SDI
Enter new value for SDI <1>: 0
Sridhar
Software QA Engineer
Autodesk, Inc
Sridhar Subramani
Senior Product Owner
Message 3 of 8
ScottSwens
in reply to: ScottSwens
That worked. Thank you.
Just curious, what is SDI system variable?
Message 4 of 8
SDI stands for Single Document Interface. If the value is set to 1, only one drawing can be opened at a time. If 0, then it is multiple document interface.
Sridhar Subramani
Message 5 of 8
ScottSwens
ok, thanks for your help.
Message 6 of 8
why everytime i open a new cad file always go to the new cad windows? how to fix this problem? is there any setting to reset to default so i can open a few file in just one windows?
Tags (2)
Message 7 of 8
Message 8 of 8
COMMAND - SDI ENTER 0 ENTER
”Boost
