AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
How to change planes in 3D AutoCAD R14
3 REPLIES 3
chris77104
33437 Views, 3 Replies
How do I change the plane that i am working in when I am in 3D mode in AutoCAD R14? F5 does nothing.
[The subject line of this post has been edited for clarity by cheryl.buck from: changing planes in 3D autocad]
3 REPLIES 3
pgwaltney
in reply to: chris77104
AutoCAD doesn't really have a "3D" mode per se, and F5 is simply an isoplane function as far as I know. Best way to change the "Workplane" that I know of is by using 3 point UCS.
erwin
F5 is for 2D drawings in iso view, when your on "3D" your using the X,Y, & Z axis... so when you want to change the plane first have a work around on your UCS arrows meaning changing it. OPEN first your toolbar "view" then choose "SE" isometric view.. then you have a 3d view in SE
UCS enter
G enter
(L/R/F/B) enter
just follow how your ucs affect by this procedures..
and last but not the least... tons of practice...
rewind.raje
in reply to: erwin
Smiley Happy    thanks it worked for me
”Boost
