Anyone know if there any way i can change the font type for the hole chart? Currently i am using a template whereby the hole chart is created using the BSI standard. I am looking way to change the table font style.
Solved by Sridhar-Autodesk. Go to Solution.
As you said, there is no other way to change hole chart text font. You have to change text style from the standard. As you know, all the text style is controlled by the standard which the dwg is using.
In order to change the font type, you may need to create a Custom standard using following steps:
Hope this helps
I try before to change the text style as mention is Step 10, but just that the button is in "grey" color and can't let me to choose other fonts.
I have attach a photo and a sample of the drawing for your reference.
Did you create a custom standard before trying Step-10?
In the attached drawing, I created a custom standard. Now the Text Style can be changed by double clicking the holechart in the drawing.
Thank,
Ok, just try again with it and it's works.Thanks for the advise...
Can i know if let said i want to delete some of my custom standard, how do i delete it?
You may remove custom standards using AMSYMSTD command.
Please note that; if a custom standard is current/active or if any objects are inserted based on this custom standard, then we cannot remove the standard.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
