AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Changing counterbore styles
3 REPLIES 3
221 Views, 3 Replies
Is there a way to change a top view of a counterbore to a bottom view without deleting and redrawing?
3 REPLIES 3
Yes.
Dbl-click the c'bore. In the dialog that pops up, the pull-down at the top has top and bottom views. Select bottom view, click Finish.
Jerry
I should have mentioned that I am using AM 2005, and I am trying to change a user counterbore.
When I 2x click the c-bore, there is no drop down menu. I can change to diameter, depth, nominal diameter, and location, but that's it.
I suppose I should have changed the values of an ANSI counterbore and then I might not have this problem.
Of course, if I drew it right to start with, I wouldn't have had the problem to start with.
I'm curious. What's the diff in a standard counterbore and a "user" one?
Jerry
”Boost
