AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Change the double click response - ATTEDIT
6 REPLIES 6
mhodson
1058 Views, 6 Replies
Is there a way to change what happens when you double click an object, to edit it?
The one that bothers me most is attribute editing on blocks. I don't like the advanced attribute editor...I use the old ATTEDIT (via shortcut) but It would be more productive if I could double click the block to activate ATTEDIT.
I'm sure there must be other people who would want to change the command that is activated by a double click.
6 REPLIES 6
mhodson
in reply to: mhodson
I guess I should mention that I'm using Mechanical 2006
I also use the old command rather than the new one...but haven't found what
your asking, would be brilliant though.
SBuurma
schreef in bericht news:5111808@discussion.autodesk.com...
I think you can use CUI command to config the double click action for
Attribute Blocks.
"SBuurma" wrote in message
news:5112427@discussion.autodesk.com...
SBuurma
Sorry, forgot to mention this is new feature in upcoming AutoCAD 2007
release and you can use the Beta version to try it out.
SBuurma
mhodson
That's great news. My company is on the subscription program so I should be getting 2007 when it comes out.
mhodson
I've found what I was looking for.
Paste this line
(defun c:eattedit() (command "ddatte"))
into your acaddoc.lsp file.
”Boost
