Sam is right about the indication of the path in which ACM will search for
border drawings.
However, the path is not editable.
For your information, the path is formulated based on the following:
//gen/Dwg/Format
Rgds,
Low Li San
Software Developer
Manufacturing Solutions Division
"Sam Hochberg" wrote in message
news:5249270@discussion.autodesk.com...
Options command, AM:Preferences tab, System button, Paths node, DwgTitle
line...
Sam Hochberg
Inventor Certified Expert
Not too bad at AutoCAD either
wrote in message news:5248620@discussion.autodesk.com...
By default AutoCAD looks for borders and the like in "C:\Program
Files\Autodesk\Acadm 2006\Acadm\Gen\DWG" (or wherever you have installed
Autocad. That is all fine and dandy, until you have a lot of users and the
boss has decided that he really wants to revamp the border style. That is
why we usually have the customization files on a shared network drive, and
that works pretty okay, only, in this case I seem to be unable to convince
AutoCAD to go look there. Is there a setting to change the paths or is it
hardcoded and is the only way to deploy a new style to all users installing
by hand?
