<ASMETZER@A-S-H.COM> wrotei
in message
href="news:6165805@discussion.autodesk.com">news:6165805@discussion.autodesk.com...
recently loaded Autocad Mechanical 2009. We were using 2008. the command to
draw centerlines "AMCENINBET" appears to have been deleted. it was very
useful. does anyone know how to gert theis command to work in 2009 or a lisp
routine to do the same thing.
I have another question about this command. I am also using Acad 2009 Mechanical, and find it useful. BUT... is there a setting to define the layer that the centre-line is placed on? I want it to be placed on my company standard Centre-line layer, not AM_7, or whatever it is. Is this possible? Thanks.
Yes, it's possible.
You can go to Object Property Settings to change it by Options dialog->AM:Standards tab->Double click Standard node->Click Settings in Standard Settings dialog.
In the Object Property Settings dialog, select Drafting and find Centerline, narrow, then change the layer from AM_7 to the one you like. Ok all dialogs.
I have a lisp routine for making center lines out of other lines, it changes the Linetype to center and the color to red. It does not change its layer though it could be made to do so. I am more curious as to why your company has a standard layer called center line. I am also wondering if you have a standard layer called hidden, if so I may be able to increase your production by changing the way you do things. I am 65 and retired but have been using autocrat since version 2.3 or something like that. I was also a job shopper and everywhere I went I was about twice as fast as the company's best man. This is strictly due to technique . I found out about autolisp early and I have rarely used a button or icon or tablet since. ALL my commands are input at the keyboard. 1,2 sometimes 3 letters. I have no
menus on my screen. Most autocadders have no idea what I'm doing when they watch me work. I have a list routine called (rc) stands for rotate crosshairs. Select a line and the crosshairs align with the line. Turn on ortho and all lines
will align with the selected line. It does not work with text but it could. if interested let me know and I will write the program and send it to you'
best regards
Greg
