AutoCAD Mechanical General Discussion
Active Contributor
VeronicaSmith5891
Message 1 of 6 (201 Views)
Cannot preview blocks from library while inserting
201 Views, 5 Replies
10-25-2012 08:14 AM
We just upgraded to 2013 Mechanical and I found that when I insert a block from my Library it inserts right where my cursor lays but I cannot see/preview this block until it is inputted.  We used to be able to do this in previous versions.  I looked in the Edits and Options for the Library and there seems to be no setting to turn this on.
Any ideas?
Thanks!
Product Support
jingy
Message 2 of 6 (187 Views)
Re: Cannot preview blocks from library while inserting
10-28-2012 09:44 PM in reply to: VeronicaSmith5891
I have checked with version abut ACM at my site, it's same result.
I am not clearly with the meaning of "where my cursor". Does that mean the block is inserted on the point when you click on the drawing area?
Could you upload the recordings of your action? It will help me understand what issue you have met.
Yong Jing
Product Support Specialist
Frontline Technical Support, CSS. GCSO
Active Contributor
VeronicaSmith5891
Message 3 of 6 (181 Views)
10-29-2012 05:04 AM in reply to: VeronicaSmith5891
"Does that mean the block is inserted on the point when you click on the drawing area?"
That is exactly what I mean.
Product Support
jingy
Message 4 of 6 (171 Views)
11-01-2012 08:53 PM in reply to: VeronicaSmith5891
As I said in last message, there is no differnce in different version. From this point, it should be as-designed.
If you think there is some difference, could you upload the recording of your action?  I could help you research it.
Yong Jing
RichardGHawley1971
Message 5 of 6 (86 Views)
08-17-2013 11:26 AM in reply to: jingy
I have the same issue in 2014.
I choose a block, I then go to insert it but although it inserts correctly at the base point, the block is not visible at all at the curosshair cursor, until you click to finish the operation.
This means you cannot rotate it, or scale it either - because you can't see it until you've finished.
Does this mean you have a major bug in your system?  I was thinking it was a system variable needing changing but even the technicians don't seem to be able to recognise this issue?
Product Support
jingy
Message 6 of 6 (66 Views)
08-27-2013 02:25 AM in reply to: RichardGHawley1971
I have reported thsi wish list to Dev team.
Yong Jing
