AutoCAD Mechanical General Discussion
Member
JamesCutler7531
Message 1 of 2 (480 Views)
Cannot install AutoCAD mechanical 2010 on Windows 7 64bit SP1
480 Views, 1 Replies
02-23-2012 04:51 AM
When I try to install the suite I get the error: "the system cannot open the file specified" I cannot recall the file it cant find but I know it is there on the CD. So as a work around I installed each part of the suite individually. Then when I finally got to installing AutoCAD mechanical I get the error:
"the system cannot open the file specified............acad.mst" I hav tried installing off the disc, off the local drive. Same issue occurs. I am logged in as admin, UAC is off. Brand new laptop only a couple of days old.
It says here http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14053691&linkID=9240897 that it should work :smileysad:
Tried re-installing .net framework to see if it was that but to no avail.
Employee
michaelsu
Message 2 of 2 (393 Views)
Re: Cannot install AutoCAD mechanical 2010 on Windows 7 64bit SP1
04-10-2012 08:55 PM in reply to: JamesCutler7531
I am wondering whether the install media is corrupt or not? Maybe you can request a install media and try.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
