AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Can't launch Autocad Mechanical 2013
1 REPLY 1
jp_charlier
407 Views, 1 Reply
Hi!
When I try to open autocad mechanical 2013, it immediately closes without error message.
I tried to repair and reinstall, I updated the drivers (windows xp 32bit) but it still doesn't work.
I only have autocad that is not working. All other Inventor 2013 tools are working properly.
Does somebody have a solution?
Thanks!
1 REPLY 1
Thank you for having posted your question in this discussion group
Here are interesting links on this subject:
If you use Network license:
http://usa.autodesk.com/getdoc/id=TS14908069
If you use standalone license:
http://usa.autodesk.com/getdoc/id=TS15176093
I hope that will help
Best Regards
Nicolas Bourquin
”Boost
