AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
can't close drawing
8 REPLIES 8
Message 1 of 9
cean_au
2509 Views, 8 Replies
can't close drawing
the tool tip is working, but you just can't close the drawing.
8 REPLIES 8
Message 2 of 9
Sridhar-Autodesk
in reply to: cean_au
You may either close the navbar using NAVBAR: OFF or dock th nav bar to the bottom right corner.
Sridhar Subramani
Senior Product Owner
Message 3 of 9
cean_au
in reply to: Sridhar-Autodesk
If you click the close button directly, 2 out 10 times may working.
Is it designed like this?
Message 4 of 9
Sridhar-Autodesk
This issue is already logged in our system and development team is working on it.  Looks like, Navbar is too close to the Close button and hence suggested you a workaround in my previous reply.
Sridhar Subramani
Message 5 of 9
cean_au
inventor doesn't has this problem.
Message 6 of 9
cean_au
inventor can highlight the button, but AM can't.
AM always has this problem to tell where I am.
Always got lost.
Message 7 of 9
cean_au
does this been fixed?
it's pain to use acm2012 now.
Message 8 of 9
Sridhar-Autodesk
This issue is not yet fixed.  I will keep you posted when there is an update from development team.
Sridhar Subramani
Message 9 of 9
hey,
Try command: SDI en turn it from 1 to 0.
Greetz
”Boost
