Dear all
Please help me in this case.
I have download the file from this link :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17125406&linkID=9240898
I try to install but I can not. my friend can install
Please see the message in attached files.
- do you have AutoCAD Mechanical 2011 installed?
- do you have Update 1 installed?
- do you have the correct version of the update (32-bit / 64-bit)?
-I have installed autocad mechanical and it run ok
-I have update the first one before. I try to install it again but have the same message
-the verson is correct 64 bit
thanks
