AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Calculation
8 REPLIES 8
Message 1 of 9
AWBoluijt
1950 Views, 8 Replies
Calculation
I got a error on 5 Cad machines! when i do a calculation i got a text box with "Gefmsg Gefeko" See the attachment.
All the 5 machines are running on XP 64bit with Autocad Mechanical 2009 sp1 (64bit).
I have try to reinstall, use default project, standard acad.dwt.
I have no ideas any more.
I hope some one can tel me what to do.
regard André
8 REPLIES 8
Message 2 of 9
in reply to: AWBoluijt
One of the reasons could be that AutoCAD Mechanical is unable to locate
Gefeko.mld file. Invoke AMOPTIONS command > "AM:Preferences" tab > click
"System" button > in the "System Editor" dialog locate "Paths" > take note
of the path specified for "MldPath" (refer to the attached picture for more
information). Ensure that Gefeko.mld file is located at this location you
just took note of. On an English installation of AutoCAD Mechanical 2009,
Gefeko.mld and other .mld files are usually located at "C:\documents and
settings\all users\documents\autodesk\acadm 2009\acadm\translator\".
Lakshmanan L L
Product Designer
Manufacturing Solutions Division
Message 3 of 9
AWBoluijt
I have fount it there is a faulty is the path.
Documents => Documenten
See attachment.
I Have change the register path Acadm\Preferences\Data\gen\Paths PublicPath
and now it working.
Thank for the information!
Message 4 of 9
shashankabehera
Can you please let me know how to change the MldPath in system editor of AutoCAD mechanical 2010 (Run in Win 7) from
C:\Users\Public\Documents\Autodesk\ACADM 2010\Acadm\TRANSLATOR
to
C:\Windows\Profiles\All Users\Documents\Autodesk\ACADM 2010\ACADM\TRANSLATOR.
Shashanka.
Shashanka
Message 5 of 9
michaelsu
in reply to: shashankabehera
Hi Shashanka,
Please check the path stored under HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8005:409\Profiles\<<ACADMPP>>\Acadm\Preferences\Data\gen\Paths\PublicPath and then re-launch the product.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Message 6 of 9
shashankabehera
in reply to: michaelsu
Hi Michael,
Thanks for you prompt responce,
The good thing is your suggested workaround is updating the MldPath value on system editor of ACADM (Pls refer attached file) but  I’m getting some ACAD message in the text box  (Pls refer attached file), even though Content Library part inserted to drawing.Also as per the ACAD message I checked the path & all the mld files are available there. Kindly suggest.
Shashanka
Shashanka
Message 7 of 9
michaelsu
Hi Shashanka,
In my machine (win7 64), I input PublicPath as below:
Then it will automatically look for the path under it. In options dialog the path looks like below.
C:\Users\Public\Documents\Autodesk\ACADM 2010\ACADM\TRANSLATOR
Maybe you can do similar thing in your machine.
Hope it helps.
Thanks.
Michael Su
SQA Engineer
Message 8 of 9
shashankabehera
Hi Michael,
I had the same setting as your machine (C:\Users\Public\Documents\Autodesk\ACADM 2010\), but due to some specific need I have to change the path to C:\Windows\Profiles\All Users\Documents\Autodesk\ACADM 2010\ACADM\TRANSLATOR.
I have the same content at both the path, but getting the text box message after updating the path to C:\Windows\Profiles\All Users\Documents\Autodesk\ACADM 2010\ACADM\TRANSLATOR.
Any suggestion?
Thanks & Regards
Shashanka
Shashanka
Message 9 of 9
michaelsu
Hi Shashanka,
It looks strange to me.
Can you make sure all mld files are there in that folder you specify below?
When you set MLDpath in the registry, you don't have to add "acadm\translator". The system will add it for you in Options dialog.
Thanks.
Michael Su
SQA Engineer
”Boost
