Hi Bob,
I am assuming you are talking about the parts list, if that's the case,
change your insertion point from bottom right (or left) to top right (or
left). This changes not only the insertion point, but also the heading
location and the numbering direction.
You can make the change each time you place a parts list using the dropdown
list within the Parts List dialog box or you can permanently change it using
a similar dropdown list found in the Parts List element of your standard. If
you decide to make the change permanently, make sure you do it in your
template drawing.
Hope this helps.
Andrew de Leon
AutoCAD Mechanical Product Designer
Mechanical Solutions Division
Autodesk, Inc.
wrote in message news:5267255@discussion.autodesk.com...
Is it possible to REVERSE the direction of the BOM inserted into a drawing -
ie from TOP to BOTTOM rather than the default BOTTOM to TOP?
Bob
