>I can change the text color, but not the grid color. <
Go to Tools > Options
Select the AM: Standards tab
Double-click on the Layers/Objects node in the tree under the active
standard
Select the Objects tab
Scroll down and find Parts List Cell Lines
You can change the default color, layer, linetype of this and most other
acad/m objects here.
>Also, I'm using the custom filter. Is there any way to filter BOM lists by
more than one custom filter?<
Sure. In the Parts List dialog box, just right-click in the Filters/Groups
window and select Add Filter where you added the first one.
Chris Palmatier
AutoCAD Mechanical Product Design Team
"moores" wrote in message
news:4838825.1091805540897.JavaMail.jive@jiveforum2.autodesk.com...
> I have inserted a BOM table in paperspace on a drawing. The default grid
color is yellow. I can change the text color, but not the grid color.
> I changed the text layer color to blue, which changes the grid color to
blue in paperspace, but when I plot (or preview plot) the grid is still
yellow!
