AutoCAD Mechanical General Discussion
Active Contributor
leandrav
Message 1 of 6 (530 Views)
ballon text size
530 Views, 5 Replies
12-03-2012 12:12 AM
I am new to the world of bom's, partlists & balloons
I am having trouble changing the text size of the text in the balloons.
Can anybody help me with this?
Hi Leandra,
Instead of changing text height, have you thought about changing the scale like set AMSYMSCALE to 100? If you place a balloon, you should be able to see the text inside the balloon.
Hope it helps.
ukrainian
Message 2 of 6 (512 Views)
Re: ballon text size
12-03-2012 10:48 PM in reply to: leandrav
Options > AM: Standards > Balloon > Default style > Standard (click three dots) > Text > Height
(ACADM 2008)
Active Contributor
leandrav
Message 3 of 6 (507 Views)
12-03-2012 10:55 PM in reply to: leandrav
Thanks for the reply.
I have tried that. I can't seem to get it higher than a size of 20.
I can't put my own size in I can only choose from what is in the drop down list.
Active Contributor
leandrav
Message 4 of 6 (494 Views)
12-05-2012 10:39 PM in reply to: leandrav
I have attached a picture in hopes that this will help someone give me advise.
This s a pdf to a scale of 1:30 & on this you can't really see the numbers in the balloon that well.
I am looking for a way that i can increase the size of the text so that it can be read at a scale of 1:100 at least.
I have tried changing the size as perviously mentioned but I can't go bigger then 20 & I can't pick my own size. I can only pick from what is on the list
Leandra
Employee
michaelsu
Message 5 of 6 (489 Views)
12-06-2012 12:54 AM in reply to: leandrav
Hi Leandra,
Hope it helps.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Active Contributor
leandrav
Message 6 of 6 (484 Views)
12-06-2012 01:08 AM in reply to: michaelsu
THANK YOU!!!
That works perfectly!!
You are a genius .:smileyvery-happy:
