Windows XP machine and Autocad Mechnical 2006 I have the "options" setting "Open and Save" "File Save: Save as: AutoCAD Mechnical 2004 drawing. When I open a drawing file with 3D enities and create my views using the amdwgview command and close the drawing and hit save. My views are still there when I open the drawing back up. If I follow the same steps and use SAVE AS from the Files menu I loose my views. Can this be checked?
Solved by Sridhar-Autodesk. Go to Solution.
In AutoCAD Mechanical 2006 option dialog>>Open and Save tab>>We don't have AutoCAD Mechanical 2004 drawing format. Below are the formats that are listed.
When we select the first one "AutoCAD 2004 Drawing" format, it is actually saving in AutoCAD Mechanical 2006 drawing format. Hence the drawing views are seen when the drawing is reopen after a save.
In order to avoid such confusions, from AutoCAD Mechanical 2011 onwards, All AutoCAD Mechanical file formats were listed and allowed to set one of AutoCAD Mechanical file formats as default. Therefore formats that are seen in the options dialog matches with the formats seen when SaveAs command is used.
Hope this answers the question.
Thanks, for this information I was under the impression that it was 2004 Mechnical.
