After opening Autodesk Reference Manager 2014 - when trying to add drawings (to repath some xrefs) - the program crashes everytime I attempt to even add a drawing - any drawing!
Even if AutoCAD Mechanical 2014 is open or closed....
Ideas? Suggestions
Cheers
DP
Solved by david.penney00. Go to Solution.
I tried to add a drawing in Reference Manager and edit its path but didn't see the crash you mentioned.
When you see the crash, did you see the customer error report dialog? If so, please fill in your email address and steps to reproduce.
Let me know your email address so we can have a further look at your issue.
Hi Michael,
I eventually uninstalled the Product Design Suite over the weekend, and reinstalled this morning. and have finally set everything up again...and about 10 minutes ago, re-tested the Reference Manager and it is now working OK!
Many thanks for your reply.
Cheers
David Penney
